IflewbyU2
Flight distance : 1066076 ft
IflewbyU2 Posted at 2018-5-12 13:09
Same! My Mavic Air is slightly soft on the right side too, every video/image I shoot. more near 1/3 from the right than on the right edge. But here is the interesting thing, something you need to check: the problem doesn't exist if you walk around holding the drone and snapping pictures (on mine anyway). So it is a flight vibration problem, not a lens problem. A year or more back, I got a Mavic Pro that had the same problem, only about 20 times worse. That was how I knew to check it when not flying. So check your images and video when not in flight, if the blur goes away, you too have a vibration problem. My only possible offering of a fix is to try other sets of props to see if the results are better, or find a way to balance these tiny props.
I have switched to a new set of props, no help. Same exact level of softness in the exact same place. So I think prop vibrations can be ruled out a the source. I am now wondering if the new gimbal support system in the Air is still not perfect. I believe it is much better thought through than that of the Mavic Pro, but possibly still not perfect. I am going to try shooting some video while walking it around instead of flying, again. Gotta check again to see if the blur is present when not flying at all. |
