Cetacean
Flight distance : 2528264 ft
Aloha CT 007,
Yes, you can burn out your antennae system by using your RC without the antennae screwed in. Goggles and remote controllers that ship without the antennae screwed in will usually have a warning that you can burn out your system if you do not attach your antennae. Look though your packaging to see if you can find your warning.
Before some of the new goggle users get worried about their HDMI goggles, the fast (as in almost no lag time) analog antennae system is not used when the digital HDMI cable is used. For example, with Fat Shark goggles, if you use the HDMI cable setup, the antennae do not have to be installed and sometimes the circuitboard needs to be purchased separately. This happened to me and it had the warning.
When I bought my P2 v3 I tried to extend the range and I think I burned out my transmission system due to an accidental disconnection. Oh well it happens when you are learning.
Hope this helps!
Aloha and Drone On! |
