Gimbal callibration
327 3 2018-5-10
Soundwave79
Flight distance : 9137 ft
Malaysia
Recently i've noticed that my camera is not align horizontally straight. Each time before fly, i've to callibrate the gimbal. Is this normal or my camera need to be repaired
2018-5-10
Otjep
Flight distance : 328461 ft
Indonesia
Hi Soundwave79, May be you should check to DJI Service Center. Because usually the camera doesn't need to be calibrate everytime. As long as you place the drone on the flat ground. Usually once calibrated it will come back as it is. Only need to be calibrated for sometimes, but I don't know which drone are you talking about? Is that the latest P4 or the previous version... many things could possibly happened.
2018-5-10
Soundwave79
Malaysia
Otjep Posted at 2018-5-10 06:15
Thank you... i'll check with dji service asap
2018-5-10
Soundwave79
Malaysia
2018-5-10
