S-e-ven
Flight distance : 5922034 ft
Thailand
That is normal, the Spark, if flown below the RTH height settings, is ascending to this RTH height first.
If reached, it flys straight back to home and descends just over the homepoint
But YOU can set the RTH altitude. Default is 30m, if I recall that right
It need to be HIGHER, as the houses, poles, ...., in possible flightpath.
Because when further away as 100m from the homepoint, OA is not working because of higher Speed (In the hight 30ies kph) .
And if the RTH happens behind something, .....
https://forum.dji.com/forum.php? ... 3&page=1#pid1245688 |
