It says no internet connection but connected to the app
8372 4 2018-5-12
fans58fb8d1c
Malaysia
Why it’s says no internet connection but connected to the Dji app? I’ve restarted my phone and Rc but still encountering this problem. I’ve just face this problem lately. What should I do to solve this ?
2018-5-12
fans58fb8d1c
Malaysia
It says no internet connection but connected to the dji app
2018-5-12
S-e-ven
Flight distance : 5922034 ft
Your RC or your Spark is a Wifi but with no internet.
That is the reason for the message. Tell it to stay connected even if no internet.
"No" is to click if I remember that roght
2018-5-12
DMX_MT
Malta
fans58fb8d1c Posted at 2018-5-12 03:38
As S-e-ven explained, this is how they Connect -
Remote Control - Sends Wifi Signal --->>> <<<--- Connects to Remote Control Wifi Signal - Phone
The Remote doesnt need Internet to Fly the Drone. You connect to the Remote's Wifi so that the Remote will send you Information and Live Video on the Phone, and from the Phone you can send Settings / Controls that will be Transmitted 1) First to the Remote, 2) Then to the Spark Aircraft.
Your Setup is Correct. The Remote Wifi will always show 'NO INTERNET' as its not a Signal from the Internet Provider Modem Wifi Antenna that will have Internet Data in it.
Note - During Flight you maybe will need Internet only when Cacheing Maps, Android can Download Maps and IOS can do it just Before the Flight, unless You dont have Cellular Data.
Its just a WIFI CONNECTION (Without Internet), you can take an example of BlueTooth. They dont use Bluetooth as Wifi is more Longer Range and Stronger Signal
You can also use OTG Cable if you want and connect to Remote to Phone via a Cable. Its like having a Wired Connection vs an Wifi Air Connection, for me wired is more Stable. For Android Version 4.1.15 and now the NEW Version 4.2.12 Supports it. If you are using IOS (Apple) you wont have any issues with whatever Version you use. Many suggest OTG over Wifi, as it reduces the number of disconnects with the Remote Controller, and you will have a Better Video Live Feed.
2018-5-12
Flighty
Flight distance : 1977175 ft
Croatia
It's telling you that you do not have normal WiFi / Internet connection as you have every day for normal Apps,,,,, but you are connected to your RC,, perfectly normal situation to go fly,,
2018-5-12
