Cannot get Mavic air lens off to put Nd filters
238 1 2018-5-12
fans0adf2405
Cannot seem to get this lens off just bought it very frustrating and no do not want to damahe it to put on the dji nd filters
2018-5-12
msinger
Flight distance : 228255 ft
Try this:
  • Position three fingers evenly around the outside of the ring (so you can apply even pressure) like this:
  • Grip the ring as loosely as possible. If you grip the ring with a  lot of force and/or attempt to use tools to remove it, it likely won't  budge and you might damage it.
  • Hold the camera steady with your other hand.
  • Push the ring against the camera with a little bit of pressure.
  • Turn the ring counterclockwise.
  • Wear a rubber glove if the ring slips through your fingers.
2018-5-12
