I just tried out D-log with my phantom 4 pro, but i experienced a lot of noise, especially in the grass.(see attached video)
I filmed at 4k 24 fps 50 shutter in pal with -1 all over the board. I used the histogram to check the exposure and tried to hold the histogram mountain in the middle.
Is this because the 500 ISO or is it because of my settings? Or should I just use cinelike as I used before but would like to get a bit more dynamic range in my video's.
Is this the first time that you encounter this issue? You may want to reset the camera settings and you may try to capture another video and compare it. Thank you!
D-Log is for you to modify during post, you video looks like its straight from the card with no work done, if you dont want to post edit then choose another setting
