Gimbal speed
436 3 2018-5-12
Zephyr54
Hi everyone,
I was wondering how do you change gimbal speed when it pans up and down, mine goes to quickly. Also, what are your gimbal speed settings?
2018-5-12
Just another drone guy
Flight distance : 875499 ft
I'm pretty sure you can go to the three dots in the corner when you are seeing wh the camera sees, then scroll down until you see a camera icon. then that's where you're gimbal settings should be, also make sure you also check"advance settings".
2018-5-12
Flybee
Flight distance : 2203983 ft
Sweden
There is a lot of good tutorials on YT that explain gimbal and other values for your drone,
this one is a very good example
Good luck
2018-5-12
Tealk
Flight distance : 544222 ft
Romania
keep it at low speed as you can for a good quality of pans
2018-5-12
