Fan issue
476 5 2018-5-13
fansbd663903
Flight distance : 2338192 ft
Is this fan supposed to start up immediately on power up or does it take a bit before engaging.
2018-5-13
WInged Eye
Flight distance : 953983 ft
I think it's regulated by a temp sensor of some sort. It circulates air when cooling is needed. Leave it running for a while and see if it kicks on?
2018-5-13
fansbd663903
@DJI. Any definite info on this?
2018-5-13
Hi there, I checked our drone and the fans in this position start up after powering on, please allow us some time, I will verify with our engineers and come back to you soon, thanks for your patience.
2018-5-14
fansbd663903
@DJI Mindy
Thanks
Please also confirm with the engineers that the only way to replace the fan in question is to replace the entire bottom shell.
2018-5-14
fansbd663903 Posted at 2018-5-14 03:47
@DJI Mindy
Thanks
Sorry to have kept you waiting, the fans should spin when powering on, for your issue, it is suggested to send in for evaluation since it could be the defect of the fans or the main controller fails to supply power.
2018-5-17
