Aardvark
Flight distance : 384432 ft
When you did the IMU calibration, was it on a level surface (check with spirit level) ?
There is also a small possibility that a sensor calibration might help. When the aircraft is at 10 metres or below the VPS and ultrasonic sensors help hold position. It would be worth doing the sensor calibration using DJI Assistant 2. |
