Vyborny83
Flight distance : 166014 ft
Czechia
Won't help. I am unable to change the band with or without the OTG cable, I have even contacted the support, provided them with an explanation and some screenshots. Their answer was that there is no problem with the App, my Spark must be faulty and I should send it for repairs ... DJI apparently do not care about this one.
The first cases of this problem go back to the firmware .701, it worked fine with older .600, unfortunately I can't downgrade to it via DJI Assistant 2 anymore and when I requested it via DJI Support to verify whether it helps with this bug they simply closed that case without answer. Downgrading to older version of DJI GO 4 won't help either. |
