Red Waypoint
Sorry, just launched the aplication some days ago. Soon I will provide tutorials. Some info:
1. Plan your mission. (Recommended in Offline Mode)
Adjust the waypoint default parameters (GPS coordinates) taking into account the height.
Add Waypoints (the blue eye) creating the desired path.
You can add Waypoints in several geometry patterns (lines, circles, square, grid). Click over a single waypoint to change its height. In addition adjust the heading(0 NORTH, 90 EAST, 180 SOUTH, 270 WEST).
Another parameters is the gimbal (point forward with 0 degrees or downward 90 degrees). When the mission is ready save it.
2. Fly your mission.
Connect your Spark with your remote Controller and your Android to the WiFi.
Enter in FLY mode and load the mission created.
If your drone has GPS coordinates it will appear a Green dot (HOME POINT).
If you want to check your mission before launching, you can use the simulator "S" Button.
Before executing the mission you must take off (With the up arrow button).
Now you can fly manually. If you want to execute the mission and fly autonomously click on the PLAY button.
PAUSE button will stop your drone, and for resuming the mission just click again PLAY. The STOP button ends the mission.
Adjust some parameters for the mission such as the drone speed, action after finished and the drone heading. Set a POI Point Of Interest (The Orange point) and the drone will point to that coordinate.
3. Record your videos.
Go to the first person view, and Long Click the screen, you will have a full camera view. Adjust your camera parameters and focus on your videos.
Play with the gimbal! Adjust the speed movement and control it manually, you will create amazing videos! |
