djiuser_95LoVTTxNcTg
KurtVD Posted at 2018-5-14 18:41
The Spark has no internal memory, unless you install an SD card. If you have installed an SD card, it will (should) show up if you connect the Spark to your computer via USB cable. The cached files are stored on your phone, there is a setting in the DJI GO app where you can set the size limit of the cache. I have never quite figured out how to retrieve the cached files and save them, but then I never really tried, since I never needed them.
Thanks for your reply! I got confused with the Mavic Air (which does have an internal storage). Turns out if the Spark does not have a micro SD card installed, it will directly store the photos and videos on the DJI Go 4 app from the live stream. I also figured out how to get those photos and videos out of the app. I connected my iPhone to my computer and then used iTunes to get them. |
