Kryml Munsta
Flight distance : 185262 ft
luciens Posted at 2018-5-15 14:24
Yes, the "auto" frequency selection function is broken. Intermittent severely reduced range is the symptom. You can work around it by hard-assigning an actual channel on either 2.4 or 5.8 ghz, which will restore full range, even with the 0100 firmware this will work.
I believe DJI is aware of this too, but like all the other problems, nobody but them knows when or if these will be fixed.
did you meanthe Workaround (manual frequency selection) will work "even with 0400 firmware"?
Today i downgraded the googles (only the googles) back to FW 0100 and everything seems to be back to normal (range , video quality and framerate) |
