Genghis9
Oh I wish you well, as Geebax was spot on, compass calibrations are no longer necessary unless the system is telling you it is.
Really...they supply you with this capability so it means use it...sooo, they supply you with an airbag in your vehicle how often do you use it? They equip F16s with ejection seats, but I don't see pilots exiting the jet using that capability...seriously.
I think it is swell that you can adjust the timing on your car, although I wonder if you are dating yourself as nearly all modern vehicles have electronic timing that can be adjusted via computer automation or precisely using a computer interface. So short of a computer error or a tech who makes an error it should never require adjustment. However, it is that last point that is the very reason for not performing a compass calibration, human error. If you take a perfectly flyable bird and do an unnecessary or non-required calibration and introduce error in to the system when doing so, then who is at fault you or DJI...I'm betting you'll blame DJI.
Lastly, you cannot equate a compass or its calibration with an engine's timing or adjustment or almost anything mechanical. In this circumstance it is about the bird's compasses, the birds design, construction, & configuration, and the earth's magnetic field (which can be locally effected by the environment such as distorted magnetic field, metal, etc.). A compass swing on an aircraft is only performed anytime a configuration change is done or a major change has been performed such as an engine swap out or an upgrade to the electronics etc. Otherwise, you can fly for years before a new swing (similar to a drone compass cal) is required, because it is unnecessary. It is more likely that the earth's magnetic field drift will necessitate a swing before an aircraft requirement drives it (assuming none of the above has occurred) which means you could easily go as long as a decade or more before being required.
Fly Safe! |
