HereForTheBeer
Flight distance : 5381368 ft
it has been a while since i been here and i know that this probably been mentioned many times.
a couple suggestions we need for our DJi drones..
1. auto record at take off option. i know it isnt a hardware limitation, several apps that are availble that do auto record at take off, but given the way DJi handles claims, better if Dji just adds it to the app natively...so people dont get denied claims based on using other apps with differing logging systems.
2. (Mavic Pro specific) Option to disable tap to focus on the mavic pro and just locked infinity focus, i like the ability to change focus and tap to focus, but i would like the option to lock focus to infinity for ease of use. sometimes the camera refuses to even refocus after you accedently tap the screen while in flight and all blurry means i have to waste time fixing that..
3. fix active track, simple fixes like if it reconized target again, just resume active tracking.. one of the oddities i noticed with active track is if anything breaks visual for even half a second or so, it just sits there waiting for you to click go again.. fix that please! just let it resume. i can understand if its totally out of visual range, but if its relock on target.. just resume..? please?
4. possible range issue need addressing. only change for me has been updates DJi pushes both formware and app, now im suffering from spotty range issues... not just mavic pro.. i seen spark users, mavic air users and few phantom users mentioning similar things... something changed recently and not for the best..
5. being spoiled by way game recording happens on PC here i guess.. but would be nice if say somethign just happened, but click record of take pix too late it still captured it.. because always caching video and upwards of a few minutes at a time and before and after and trim it how you like.. kinda goes with first suggestion but, still nice feature.. doesnt need to use extra ram either, could just use a "reserve" amount of space on the SD card for it like 4GB of reseve space. and just record to that area and when you tap record button or take pix it copies over last 30 seconds to a minute of recording over to normal location.
-------very long shots here but... figure why not suggest it.--------
6. Mirror function. think live streaming realtime but instead of over the internet, just to another DJi go app. even create a "cheap" wifi base station that iPhones can connect to so local mirroing is possible on devices that cannot generate own local ah-hoc network.. like "mirror-bridge"
7. secondary controller via mirroring application.. but not a full fledged second controller, a controller can control and command camera, maps and some settings and secondary functions like that.. good for being a spotter and stuff.. they can use their phoen to handle it.. however primary piolit in control can revoke control at anytime if needed..
edit: 8. activation lock! if drone is stolen and you report it stolen, dji should run a deactivation lock on the drone so no one can get it airbourne again without owners account reconnected. and it can be transfered around passively as long as you log out and disable locking ... before new owner signs in..
