HereForTheBeer
Flight distance : 5381368 ft
were you flying at night or in the dark? opti mode should position lock itself if it has enough daylight to see the ground... it will drift if its too dark for the down facing cameras to lock onto ground positioning..
edit: reuploaded your log for you: http://www.phantomhelp.com/logviewer/Z09XVTHJUB2NUJ19F8Q1/
looks like you had some GPS signals. but you took off without a good lock, it was in position mode after take off, it then flipped into ATTI mode, not opti mode.. you mentioned lack of control responding.. i cant really tell you that or not, but i do see that VPS distance is missing at times, incdating either too high for a lock (4 meters isnt too high) , malfunctioning sensors or too dark out for a good lock.
