What it means, If I want to use Litchi i have to start DJI go first?
Yes. Litchi’s instructions clearly state that you must be current on all firmware before using it. Apparently it relies on aircraft, battery, and remote to be up to date with their versions / SDK.
No you don’t you can just start up Aircraft sign into your dji app then close it down, you will never be asked to sign in again unless you have signed out it’s very simple and can be done from home.
Hi, I'm sorry to reply you late, hope you have solved the issue, it is recommended to use the DJI GO4 app to fly the drone. If there is any further issue, please feel free to let us know.
