Kapplerphoto
Flight distance : 2207602 ft
When I dump my cards from the P4P on my iMac I have no problem at all. I usually dump the card to an external hard drive dedicated to drone footage.
When I dump my card using my MacBook Pro I get a few of the files that won't transfer and it says error code 36
I looked that up and it has to do with mac/windows compatibility, there is a hidden file written when you transfer files to a Windows machine and Mac OS won't handle it, stops the transfer and shows this error code 36. I have tried dumping the card to the macbook internal drive and several external drives that I know work with my iMac.
A fix is to run the files thru a cleaner command "dot_clean" in Terminal but I tried it and it doesn't make any difference.
I have never transferred anything to a windows machine
I am away and trying to do this on my laptop, i will try it on the iMac when I get back home. I have not re-used the cards.
Has anyone experienced this and if so did you find away around it?
Thanks in advance
