DJI Assistant 2 doesn't detect Mavic air controller
12Next >
11075 65 2018-5-17
Himanshu
Flight distance : 118881 ft
Hello !!  DJI Assistant 2 on my windows 7 is unable to recognize Mavic Air controller where as with aircraft doesn't have any issue. I updated the firmware as well as calibrated the air craft with Assistant 2. I tried changing USB ports and found that drivers for controller are not installed. Windows detect controller as  CDC Abstract Control Module  device. Then from another DJI mavic forum I got this link for the drivers: https://drive.google.com/file/d/ ... pYOXJRWkpzSFE/view. Downloaded, tried but still windows was unable to recognize my controller. Will be grateful If anyone who can help me in the issue .
2018-5-17
WebParrot
Flight distance : 23625 ft
As simplistic as it may sound, try a different "data" cable, too.  Many months ago I had a similar experience and learned that the controller contacts were finicky.   Otherwise I have no other ideas.
2018-5-17
Himanshu
India
WebParrot Posted at 2018-5-17 03:42
Sir I tried everything so far. Changed data cable, tried different USB ports but no result.
2018-5-17
GDL
Flight distance : 2768694 ft
This issue rised by many before already but still didn't see the fix from DJI. Don't know when they will fix it.
2018-5-17
sky6105
Flight distance : 345653 ft
here;s an another post on the same issue that I had, lots of good advice.
Old Post same issue
2018-5-17
DJI Thor
Flight distance : 13602 ft
If you are interested in, I can provide you with a beta driver to try. Let me know if you would like to access the driver.
2018-5-17
Himanshu
DJI Thor Posted at 2018-5-17 20:09
Hello Thor !! Sure please. Will try the same and let you know. Thanks
2018-5-18
WebParrot
Himanshu Posted at 2018-5-18 00:22
See Post #5 above.  [ sky6105 ], then select his link to prior thread.  In that thread, post #7, he confirms the advice works.  Delete Assist2, install "old" version of Assist2, use old Assist 2 to "update" to latest version of Assist2.  He also provides a link to the old Assist2 version.
2018-5-18
DJI Thor
Sorry for the delay, mate. Driver link sent. please connect the RC to the PC and keep the RC powering on when installing the driver. Then restart the DJI Assistant 2 and the RC and connect again. See if it helps.
2018-5-23
Himanshu
India
DJI Thor Posted at 2018-5-23 00:23
Hi Thor !!
I didn't find drivers anywhere in the reply. Did u send through some separate link?
2018-5-24
DJI Thor
Himanshu Posted at 2018-5-24 01:55
Hi Thor !!
Hi Himanshu, I am sorry, I should've made it more clear. I had sent the link via PM, please check if you have received it.
Let me know if you haven't got it, thank you.
2018-5-24
Avian
Flight distance : 89301 ft
South Africa
HI DJI Thor, please send me the Beta driver as well
2018-5-24
SBasso
Malta
Avian Posted at 2018-5-24 22:00
Sent to you buddy.
Thor has sent to me in a different occasion & worked.
Good luck.
2018-5-24
Kevjones1959
Flight distance : 61932 ft
South Africa
My software see's the controller but says "Unable to read software version"
2018-5-24
小仙女的星巴克
Flight distance : 4657841 ft
Can someone please post the beta driver? Can't seem to connect it to Windows 10.
2018-5-26
joe_gadget
Yes same here. I wasted an hour trying then gave up and did it through the phone app.
2018-5-27
FlightWork
I know this is an old thread but I am having the same RC connect issue. J have been through numerous threads with no success.
Windows 8.1 Assistatnt 2 her 1.2.4
AC connects fine. Both A.C. and remote connect through mobile device using Go 4 app.
Device manager shows warning at CDC and virtual com port.
2018-10-7
DJI Thor
小仙女的星巴克 Posted at 2018-5-26 07:57
Hi there, sorry for the late reply, I had PMd you the link, please check. Thank you.
2018-10-7
DJI Thor
joe_gadget Posted at 2018-5-27 23:33
Hi Joe, sorry for the late reply. The update can also be done via the DJI GO 4 app. However, if you would love to access the driver, you can let me know, I am glad to send to you.
2018-10-7
DJI Thor
FlightWork Posted at 2018-10-7 04:21
Hi FlightWork, please check the device manager and try to install the driver again. I will PM you the tutorial. Please check, thank you.
2018-10-7
Ken Storm
Flight distance : 178583 ft
Hi DJI Thor, could you send me the driver, I've not been able to use the assistant with the controller.
Cheers.
2018-10-7
FlightWork
DJI Thor Posted at 2018-10-7 23:22
Success!!
I used the software in the 2nd link after running Revo Uninstaller. All is well.
Thank you so very much, Thor!!
2018-10-8
DJI Thor
FlightWork Posted at 2018-10-8 05:34
Success!!
Thank you for getting back, great to know that it is working now.
2018-10-8
Nanolab
Flight distance : 122165 ft
Hi DJI Thor, could you please send me too the driver, my Win 10 doesn't see the RC here...
Thanks !
2018-10-8
fans92f6af90
Flight distance : 1018448 ft
Denmark
This does indeed look like a generic problem in  Assistant 2 that ought to be fixed by DJI, and thus be available for all users.
2018-10-8
N3CAL
Flight distance : 20778 ft
I'm as well having issues with DJI Assistant 2 (1.2.4) not recognizing the Mavic Air Remote Controller???   I've had no luck following the many posts on several related threads here!   I've reloaded the Mavic Air Firmware .500 without issues but need to reload the Remote firmware.   If there is a Beta Driver i request help in downloading it.  (not sure why DJI does not make it available to all??)
2018-10-9
Tomcatuk
Flight distance : 28743 ft
fans92f6af90 Posted at 2018-10-8 22:37
It's been a problem with some users including myself since day one, I think the solution that worked for me was to uninstall anything to do with DJI then install (I think) it was v07  an early version of DJI assistant 2 over the top and since then it worked, but thought I would give DJI Go 4 on the iphone a go for v 500 firmware and worked perfectly... saying that I've yet to fly.... Gulp!
2018-10-9
N3CAL
Well this is getting frustrating!  I just spent about an hour online chat with DJI Customer Service about this issue and was told the Mavic Air remote control is not compatible with DJI Assistant 2.   they were not able to help me!
2018-10-9
N3CAL
All I want to do is downgrade from the Mavic Air .500 Firmware / Remote Control .0200 Firmware to the previous version (.500/.0??) because I'm getting too much gimble drift and frequent severe interferrance with drop outs at close range like 100' or less.   this wasn't happening before the update.
i was able to downgrade the Mavic Air to.400 but not the remote.
2018-10-9
Mavic Dave
Flight distance : 41161 ft
DJI Thor Posted at 2018-10-8 18:18
Can you send me a link to the driver as well.  I have another post uploaded describing a constant beep with the controller when I switch it on.  My computer will not recognize the controller and the last update was via DJI Go 4.  Drone and RC are updated to latest firmware.
The problem I have is inconsistent.  It happens when I switch the RC on by itself, no drone, no phone.
Sometimes it works normally and the orange light simply flashes.  On other occasions it beeps constantly.
2018-10-9
Bluehook
Flight distance : 790814 ft
DJI Thor supplied me with this driver back in March when I was tearing my hair out -- and it worked!
2018-10-9
Bluehook
DJI Thor supplied me with this driver back in March when I was tearing my hair out -- and it worked! (Win 10)
When I updated to 0500 yesterday, same thing, Ass 2 would not see the RC -- reinstalled it and  sure enough, it worked again.
2018-10-9
N3CAL
Bluehook thank you very much for the download link!  I was finally able to downgrade the remote control back to .0100 along with .400 for the time being.  Thanks!
2018-10-9
DJI Thor
Mavic Dave Posted at 2018-10-9 12:14
Hi Dave, for the beeping issue of your RC, as you mentioned that it happened after the firmware update, I suggest that you try to refresh the firmware by the DJI Assistant 2 again.
If the issue persists, please power on the RC, connect to the DJI GO 4 app, go to the RC calibration section, check if the RC stick has input without touching them. If yes, you may need to send the RC in.
If there is no input shown on the app, please provide me with a screenshot of the firmware list (General Settings > About) and a video of this case for further confirmation.
For the driver, you can refer to the link Bluehook posted above, I will also send you again via PM, thanks.
2018-10-9
Mavic Dave
Thank you Thor for sending me the Assistant 2 beta.  It worked (apart from my virus checker blocking a couple of files which I have got around).
Anyway RC is refreshed to latest firmware and re-calibrated.
Now, we will see if it works.
2018-10-10
DJI Thor
Mavic Dave Posted at 2018-10-10 11:55
Thanks for your update, Dave. Please keep us updated about the result.
2018-10-11
Mavic Dave
DJI Thor Posted at 2018-10-11 18:38
All seems OK now, flew one battery yesterday and no issues.
Appreciate you help
2018-10-12
DJI Thor
Mavic Dave Posted at 2018-10-12 00:42
Appreciate you help
Great to know that, please do more tests when it is convenient. If there is anything abnormal, please feel free to let us know. Thanks.
2018-10-12
Mavic Dave
DJI Thor Posted at 2018-10-12 19:46
Hi Thor.  Took the Mavic out yesterday to photograph the roof of a property that we own.  I wanted to check for storm damage.  Anyway, when in hover the Mavic started to yaw to the right.  No input from the controls.  It did a 90 degree yaw to the right before I took control and centered it again.  It did this twice.
I have heard others complain of this with a previous version of firmware.  But I have never had any problems.
Brought the Mavic home.  Re-calibrated compass, RC and IMU.
I also changed the EXP Rotate left/right to 0.20
Yaw endpoint movement limit to 40
Finally I adjusted the gimbal to settings I had previously.
I hope the re calibration of the IMU has fixed this issue.
Is there anything else I should look for?
2018-10-15
Mavic Dave
Mavic Dave Posted at 2018-10-15 00:47
Update to above.  Flew one battery today and all is well again.
Hope this thing is cured.
2018-10-15
12Next >
