Spark Charging
349 10 2018-5-18
NedUK
Flight distance : 555262 ft
Can you plug the spark into a power pack like the type you would use to charge your phone to charge it?
2018-5-18
RobertWSimpson
Flight distance : 348881 ft
yessir! I do it on the regular when I'm out.  If you want an upgrade from that, consider the Spark specific charger from DJI
2018-5-18
NedUK
RobertWSimpson Posted at 2018-5-18 09:11
You mean the charging case...
Defiantly on my shopping list
2018-5-18
RobertWSimpson
NedUK Posted at 2018-5-18 09:25
good man.  In the meantime, what you're talking about works great.
2018-5-18
davidmartingraf
Flight distance : 34614662 ft
Yes, the Spark is the only drone manufactured by DJI (excluding Tello) where you can charge it using a Micro USB cable.
2018-5-18
NedUK
So this would do it
2018-5-18
Aurelian (Spark)
Flight distance : 553720 ft
You can use a powerbank to charge your Spark but you have to wait more than 3h to charge it. The Spark charger is 3 amps and the most of this powerbank they do not even reach 2 amps.
2018-5-18
NedUK
Aurelian (Spark) Posted at 2018-5-18 10:00
The one I’ve put above is 4.5 amps
2018-5-18
NedUK
Your right, 2 x 2.4amps
2018-5-18
Aurelian (Spark)
NedUK Posted at 2018-5-18 10:15
Believe me, it does not really reach 2 amps, just like the actual capacity of the power bank is much smaller, this is common in all the power bank.
2018-5-18
DJI Elektra
China
Hi, all. Spark can use QC 3.0 charger to charge their spark. If your power bank has the same specs, you can use it to charge your spark.
2018-5-19
