Drone breaking/stopping
766 16 2018-5-18
928Estates
Flight distance : 453346 ft
My drone from time to time gives the error message of some thing like this: Drone breaking, return sticks to middle
The drone stops hard in mid flight, I need to let go of the sticks and then it resumes flight, sometimes with no other issues, sometimes the same error message reappears within seconds. Any idea on that?
2018-5-18
Labroides
Flight distance : 9991457 ft
The message is about braking, not breaking.
It's telling you that the obstacle avoidance system is reacting to an obstacle.
2018-5-18
Hurley1718
Flight distance : 549295 ft
As Labroides said above its braking. Is this happening when you are close to any objects? Or is it happening in wide open areas with no objects at all nearby?
2018-5-18
Bashy
Flight distance : 549140 ft
More than likely the sun or mist/fog, rain or snow lol but the sun is the main culprit if you are no where near buildings or other objects, etc.
2018-5-18
KedDK
Flight distance : 1133038 ft
Denmark
I agree with Bashy,  most likely the sun is the reason you get the message, for the same reason my OA is permanent off, just too annoying.
What it mean is that it has braked by itself after seeing a ghost and you now have to center/release the sticks before it will move further.
2018-5-19
CanonMax
Flight distance : 6486677 ft
I also notice that this can happen when not too small insects are in front of the obstacle avoiding sensors... happened to me last Tuesday!
When this happens mid-flight somewhere in the air... it can only be this or a bird... the Phantom will continue to fly by itself...
2018-5-19
paul2660
Flight distance : 10331 ft
Sun, on the P4 Pro it happens a lot.  Interesting about insects as that might also be happening to me, as I am seeing a few bug strikes now in the summer.
But back in April, when flying back towards the sun, I had so many of the messages, I ended yawing away and flying back sideways to stop the messages.
Interesting that dji can't update firmware to allow for a more specific error and allow for the sun.
Paul Caldwell
2018-5-19
Rodger8
Flight distance : 15812070 ft
Spell Check jumped in on you.
2018-5-19
928Estates
Hurley1718 Posted at 2018-5-18 15:49
It happens in wide open areas with 0 obstacles anywhere. And yes it is braking ;-)
2018-5-19
928Estates
Sun would be a plausible explanation, as I am in AZ and mostly only fly in bright sun. Thank you all for the explanation!  Greatly appreciated.
Now on to the pesky Ultrasonic sensor error messages......:-(
2018-5-19
DJI Susan
928Estates Posted at 2018-5-19 06:24
May I know what's the flight environment when the ultrasonic sensor error appears? Does it appear frequently?
2018-5-20
rangers95
Flight distance : 584695 ft
Switzerland
its been happening to me as well , but im sure its insects, they are not big but the sensor sees them and braking occurs, weird
2018-5-21
928Estates
DJI Susan Posted at 2018-5-20 23:25
I live and fly in Arizona. It is wide open, great line of sight, sunny and clear. It does happen every flight as of lately. It has no negative effect on the flight, and I can land the drone safely again after completion of the flight. I am all UTD with the software updates.
2018-5-23
Bashy
928Estates Posted at 2018-5-23 08:28
I would turn them off chap until you feel a flight is in need of them, thats what i do and im in the UK, the sun is a rarity lol
2018-5-23
DJI Susan
Thanks for the clarification. According to your description, it sounds like the misinformation, our engineers are working on this and will fix it soon.
2018-5-25
928Estates
DJI Susan Posted at 2018-5-25 03:06
Thank you for looking into this issue.
2018-5-26
DJI Susan
928Estates Posted at 2018-5-26 08:24
You are welcome. We'll release on our website as long as there is an update.
2018-5-29
