Lucas Argentina
Argentina
Hi guys !!!
I have some questions for the specialists here !
Here they are !:
DJI GO APP:
1) do I calibrate Lens with or without handwheel
2) while calibrating lens:
A) do I have to tap in the “infinity “ distance ?
B) which distance would be that “infinity “
distance if I use Osmo Pro (NOT in the inspire drone) for vlogging and commercials videos?
C) is that “infinity” distance matchs with the “hyperfocal” distance ?
D) which is the REAL crop factor of the x5 for recording and stilling in the differents resolutions ?
E) do i have to switch to Automatic or manual focus when I calibrate lens ?
F) do I have to do the calibrate Lens at the widest aperture (f/1,7 with the DJI default lens)? What would be the others parameters while calibrating?
G) when I have to calibrate Lens ?
3) AUTO/MANUAL ASSISTANT: how does it works ?: zoom in the check the focus accuracy ?
Does it work either in photo and video mode?
Does it work even not having zoom lenses?
DJI handwheel 2:
Once the osmo and the wheel are powering on:
A) pressing the lens button for the first time I would be setting the “upper travel limit” (as the manual says) : which is that limit ? The “infinity” (or hyperfocal) distance that we defined when calibrated lens ?
B) pressing the second time the lens button we set the “ lower travel limit”: which would be it ? The closest Distance in focus (1/2 of the hyperfocal)?
C) pressing the lens button for the 3 time :
Which is the purpose ? The Manual says for reset (would be setting again the upper and the lower travel limits?)
D) calibration : do I proceed when focusing at upper and lower travel limit are not working properly?
Thanks a lot !!
Big hug from argentina !
Lucas Rudi |
