3-D
Flight distance : 635764 ft
the Mavic Air will not allow a rollback from .400
I just attempted it using the Assistant, on a Mac as well as a Windows PC. The previous firmware versions no longer show up as an option to downgrade.
So today, I did the following:
Factory reset Mavic Air
Refresh .400 firmware on Mavic Air
Refresh .100 firmware on RC Controller
Remove DJI Go 4 app and all cached data from phone
Reinstall DJI Go 4 app 4.2.16 on phone
Calibrate aircraft using the Assitant app
Calibrate Controller sticks
it is currently 3:40am, so i've still got about 3 more hours before I can go out and test to see if this helped at all. I really hope so!!
*UPDATE*
I went out this morning to see how the above procedure would fair.
It did better, but there are still issues. here is my day:
Upon takeoff, the MA rose to 3.9 ft and did stay stable this time. there wasn't any yawing or drifting. This is a marked improvement.
The Air was also responsive as i thought it should be.
Those are the good things. However, here is a list of the bad: at 300ft away (91m) the camera view began to skip. I paused and jumped around until the aircraft was under 250 ft (76m) at this point the video smoothed back out. This is a terrible development becausei base my video shots on what I see on the screen. I don't have DJI Goggles to do FPV. So i can't really steer it without seeing the view from the camera. This is putting a damper on the footage that I am getting.
I'm now also suffering a significant amount of controller disconnects. I flew around my neighborhood, and while the MA was only 400 ft away, (122m) it suffered disconnects. This is the same area that i ran my very first flights, and had no problems. Since I live here, i have launched from this exact spot many times, and only once did i experience "strong aircraft interference". and that was 1600 ft (500m) in the opposite direction of where i was flying.
I lost connection to the controller 3 times in my short flight, and RTH did not engage. I was able to gain connection again and was then able to initiate RTH. RTH did execute properly although it did not get the precise landing quite right. It landed approximately 3 ft (1m) from it's take off spot. I launched from my near the edge of my driveway. I know for a fact there is no rebar in the concrete.
I'm going out to the park today where i took a lot of footage before, so see what it does out there. I'll update this again when i return.
