Roll, Yaw & Pitch info for Phantom 4
2495 3 2018-5-18
fansc53c1d1e
Pakistan
Hello Dears,
Any way to get the roll, yaw and pitch information for the Images we capture manually at the Ground control station during Phantom 4 flight?
Guide please.
Ahsan.
2018-5-18
Nigel_
Flight distance : 388642 ft
You can get an idea of roll and pitch by looking at the roll/pitch (attitude) indicator, normally found in the bottom left corner as an alternative to the map.
If you can work out how to use the yaw/compass indication then it is on the same display, or you can look at the map where the aircraft triangle is pointing in the same direction the aircraft is.
2018-5-18
fansc53c1d1e
Pakistan
Nigel_ Posted at 2018-5-18 23:22
Thanks for the reply.
My intention is to get this info embedded in the RGB images captured using the default Phantom 4 camera OR somehow available for each captured image. Is that possible?
2018-5-18
KedDK
Flight distance : 1133038 ft
Denmark
I have no P4 but only P4P pictures, from those i can get information as the following using standalone EXIF tools. It should be possible to make a script that automate what you want, plenty of tools out there, you just need to find something that suit you.
Pitch                           : +6.60
Yaw                             : -72.50
Roll                            : -5.20
Camera Pitch                    : -6.30
Camera Yaw                      : -72.00
Camera Roll                     : +0.00
2018-5-19
