QuestB2
KedDK Posted at 2018-5-20 02:52
Is your remote powered off? - from your initial post at #1 it sound like it fails in the end of the download and newer start the upgrade part?
Try after power off the controller, removed SD in aircraft and after a reset to factory settings in Assistant2.
The controller was not powered on whilst using assistant other than when I tried to check through Go4, trying through Go4 caused go 4 to hang whilst checking aircraft for firmware update.
I am using windows ten, but I assume so are many others.
I tried removing sd card but unsuccessful.
Will try restoring factory settings but I have been reluctant as I can still use the drone, so I am concerned factory settings may upset upgraded controller interaction. |
