Warning signals
3475 11 2018-5-19
Free2be
Flight distance : 229570 ft
Belgium
Hello DJI drone folks,
It will be cool, if there are a list and explainations of the warning signals.
In the manual, I can't find nothing about it.
I fly today and receive on my Iphone 6 the follow message: Warnings: Mobile device CPU fully loaded. Related performance will be affected.
I have closed all the apps, the free memory are plenty, even the free space on my mobile.
No heating problems in Belgium.
Best Regards and fly safe!
2018-5-19
HedgeTrimmer
Might want to look at this thread https://forum.dji.com/thread-100636-9-1.html
2018-5-19
Flybee
Flight distance : 2203983 ft
Sweden
That is a problem with you phone, not the Drone it self, happens a lot to me on my Iphone 5
2018-5-19
hallmark007
Flight distance : 9827923 ft
While most are self explanatory, there are a number that are not explained. You make a very good and important point here, there should be a list available for all users. Good job.
2018-5-20
Neliusspies
Flight distance : 2151526 ft
Nauru
Had the same messages and started a habbit of clearing my device cache every week since then did not show up again
2018-5-20
Jeff7577
Flight distance : 1916821 ft
Apple has been throttling the CPU in their phones when the battery starts getting weak.
2018-5-20
HereForTheBeer
Flight distance : 5381368 ft
Jeff7577 Posted at 2018-5-20 02:34
if user is running ios 11.3 or higher they can just disable it in Battery settings on iPhone.
click on Settings -> Battery -> Battery Health (Beta)   than if iOS has decided to throttle the CPU/GPU can disable that at the risk of less battery stability.  if iOS has not throttled yet it will just say peak performance compatibility.
other factor is it is an iPhone 6 and those barely any faster than the iPhone 5S in benchmarks from years ago before throttling occured.  and its possible his or her iPhone is just doing alot of background activity, and its getting hammered.  my iPad mini 2 does same thing if i have background applications running out of control.  i get alerts in dji go 4 that cpu is overloaded and my iPad mini 2 gets warmer..
2018-5-20
Jeff7577
Bob Brown Posted at 2018-5-20 05:02
I do not see such a setting "Battery Health "beta" - iPad mini 2 - iOS version 11.3.1
(just a heads up if anyone else updates to verify the setting. it simply doesn't exist on iPad mini 2 / only an iPhone setting?)
You need to go down to battery on the left menu.
2018-5-20
Jeff7577
You are really something else. No wonder no one wants to help people around here. As a side note, you never made a statement. Statements do not end with question marks. Maybe next time post your informational link BEFORE being an ass.
2018-5-20
DJI Diana
Flight distance : 2408 ft
Hi, I'm sorry to hear about the issue that you are experiencing. Could you please restart the drone and the mobile device to try it again? If still no good luck, please try another mobile device to check if it still happens or not, thanks!
2018-5-20
HereForTheBeer
Bob Brown Posted at 2018-5-20 17:53
Really not a hill worth dying on. Sorry if I caused you any stress.
ipads dont have that, however iPhones do.  the OP mentioned his iPhone running out of resources (cpu limitation).. so i was offering a directing hand to someone else remarking on the throttling apple has done.
i mentioned my ipad mini 2 having hiccups before because its roughly same amount of computing power as the iPhone 6 has, and if i let background tasks go crazy it slows down in dji go 4 app
2018-5-20
Free2be
Belgium
Tanks for you support and advice. I will go dive deeper into this issue.
2018-5-21
