It depends on what your shooting. For example, with my Ronin MX I use RED and Sony AR7II for video, Sony A9 for photos and also use the Z30 for inspections, etc. Having the M600 allows many options with it being such a larch platform
Thanks for your interest in M600 Pro, the built-in flight control system is compatible with the following DJI gimbals and camera:
Ronin-MX, Z30, X3, X5, X5R, XT and the Z15 series HD gimbals. Please check more details here: https://www.dji.com/matrice600-pro
I hope you feel good Frankk666 about your comment....completely rude and yes I have seen that. I am not shooting professional photography, but using it for mosquito control for granular and liquid. One more simple question that I would appreciate a answer. What would work of the DJI smaller cameras for the 600 Pro? I believe the X3 and X5 will work. Will the X4S work? Thank you.
fans4d376b39 Posted at 2018-5-23 14:54
Is it because they do not have a SD card slot to record pictures and videos? I am correct to say the only camera that works is the Zenmuse X5R or least expensive camera as it has a built in SD card slot on the mount? Just trying to get the right one that works with the A3Pro and Light Bridge 2. Thank you.
One more question is what is the difference between the x3 and z3 cameras. I see a big difference in price, but most of the specs seem the same. Which one is the newest and latest? Thank you.
fans4d376b39 Posted at 2018-5-24 06:25
Z3 is 3.5X optical zoom, 2X digital; X3 is regular camera
Yes I am - quite happy.
Your post had no context, no information as to your intended use case and no background as to the research you had done to date.
In that case, directing you to the Manufacturer's page containing that information along with the link is the most appropriate and direct support possible.
