croop120
Flight distance : 6808 ft
Trinidad and Tobago
Hi, I think i may have figured it out. I have been having this issue for over a week. Anytime you try calibrating the IMU, the picture on the left of the calibration screen is supposed to prompt you when to change the drone orientation. But this does not happen, sometimes the picture is stuck and will not prompt you to turn the drone during the process. This is where the green light comes into play. The rapid green flashing light is the prompt to turn the drone. So anytime it flashes change the orientation. You can google the order of the Orientation for each step. Note: I actually start my IMU calibration with the drone on the side then the picture on the calibration screen may sometimes change to show the next orientation. I then follow the prompts until completed. I hope this helps. Thank You. |
