15matjan
Flight distance : 1158258 ft
Being quite uneasy to extract the SD card from a MA (yes, I know the trick with adhesive tape sticked to the SD but I found it unreliable and with high risk to break the slot's contacts), I wonder or suggest if any future FW could consider the possibility to download the files via onboard C-USB port and connected cable with the aircraft turned off.
Actually, one has to turn it on, with the consequently arms depletion, take off the gimbal cover, etc. Unnecessary foldings and unfoldings increasing equipment's wear and decreasing durability...
