brianoflondon
Flight distance : 1163743 ft
Israel
Here’s what to do and yes I’m finding this really confusing too.
When you are connected to the drone with the remote or direct via WiFi go into the flying screen. In the bottom right is a little Play triangle. Push that. Then you will see the videos stored on the drone. If you find the quick shot you want, press on it and it will download in high quality to your phone. It is at this point that Asteroid shots get reversed. I haven’t used very many others. From there you can save it to your phone’s photos store and share.
The version stored on the SD card will be the correct way around - only this act of pulling it to the phone seems to do the reversal thing.
You can’t do this after you shut the drone down.
