Vidjcb
Flight distance : 13416847 ft
Well, you asked, I deliver =)
First from the drone, just all picture settings in auto, make sure you have RAW + JPG so you pick all RAW photos to color grade them in Lightroom.
Because there was no important change on the light, I decide to apply the changes on my first picture to all other ones. I exported them to a new folder, so I can keep the originals in case of any further change.
Then I used Premiere File import, check Image sequence and I will automatically create a short sequence. You may consider set it to 5-6 seconds long.
Now some effects: Scale it from about 140 % at the beginning to 100% at the end. Apply the Warp stabilization effect to soft the shaking effect caused by the movement of the drone.
Finally add sound from a royalty free library or add narration and that’s all, export it and share it.
Now regarding the experience, I would keep in mind:
- Check the sunset times for your city so you should be on time before the shooting
- Make sure your battery is 100% charged,
- Firmware up to date for both DJI Go, mobile, controller and drone.
- Set the picture composition and change the shooting settings to every 5 seconds.
- Monitor the battery level to land the drone on time.
I can’t wait to see what you guys are going to do. So please don’t forget sharing it!
Enjoy!
