Landed instead of return home
1633 25 2018-5-21
DJI User466
Flight distance : 17736 ft
Had a real bad one today hit return home and instead it landed and I was just over the trees trashed my brand new dron why would this happen
2018-5-21
Eric13
Flight distance : 13875118 ft
Has the drone been within a radius of 20 meters? In that case it will not RTH but will land where it is.
2018-5-21
DJI User466
Are you kidding me I didn’t know that damn repeated I am it’s all my fault is that what you’re saying
2018-5-21
Eric13
DJI User466 Posted at 2018-5-21 11:33
You are very agressive and your problem shouldn't be attended anymore.
You didn't give any information beyond that accident. That way it is not possible to determine if you just didn't RTFM or whatever...
Good Bye - you are not worth being helped!
2018-5-21
DJI User466
Please don’t misunderstand me I’m not trying to be a jerk or anything I was just trying to say are you saying it’s my damn fault because I am at Rocky and didn’t know what I was doing this is only the third time that I had this in the air each time which for five minutes and when I returned home came home why this time was different I don’t know
2018-5-21
DJI User466
By the way I don’t see where you see any aggression out of what I said now that I just went over it
2018-5-21
RedHotPoker
Flight distance : 165105 ft
Post a link to the flight LOG please.
Follow the instructions here.
http://www.phantomhelp.com/LogViewer/Upload/
Let us have a look at what happened in the flight.
Did you record video while this tradegy transpired?
RedHotPoker
2018-5-21
AlanHd
Flight distance : 797365 ft
How can a thread disintegrate so quick., as Eric13 stated if the drone is within 20m of the home point it will land if RTH is initiated, but you didnt say where it was in this case.
Good advice is to read the manual at least three times, it’s amazing what you can miss the first couple of times when all you want to do is get the bird in the air.
2018-5-21
Eric13
DJI User466 Posted at 2018-5-21 11:44
I wasn't judging by mentioning the 20m radius.
But often RTH issues turn out about not knowing about this feature.
So take a deep breath, relax and give us more details.
The best is you provide your flight record. Click on the following link, instructions are given.
Once you did upload your flight record, revisit this thread and provide us with the link to your flight record.
There are lots of experts here ready to help.
2018-5-21
DJI User466
If someone can tell me how to unplug my flat rock Ridge and I would be more than happy to
2018-5-21
ALABAMA
Flight distance : 10442687 ft
466, How old are you and exactly what is flat rock ridge?
2018-5-21
Oldav8tor
When I was first flying some not necessarily older but indeed wiser pilots made the suggestion that I thoroughly read the manual and ease into learning to fly my P4A.  It was certainly good advice and I recommend the same to everyone.  You need to be careful setting up and using the RTH mode and also need to be aware of how the obstacle avoidance system works (and when it doesn't.)  Me, I prefer to manually fly my drone as much as possible and I definitely make smoother landings than the drone does in auto-land.  Sorry about your troubles but good luck!
2018-5-21
DJI User466
Please help me understand this I was 519 feet away hit return home and it landed did I do something wrong
2018-5-21
Labroides
Flight distance : 9991457 ft
DJI User466 Posted at 2018-5-21 13:36
If your Phantom was well over 20 metres from home, the cause of the incident will be something else.
The only way to work out what happened is to look at the flight data.
The way to do that is:
Go to http://www.phantomhelp.com/LogViewer/Upload/
Follow the instructions there to upload your flight record from your phone or tablet.
Come back and post a link to the report it gives you.
Someone should be able to look at the data and make sense of it.
2018-5-21
theGrindLab.com
Flight distance : 1375846 ft
What was your battery level when this happened? Perhaps you were at a critically low level and set to land instead of RTH.
2018-5-21
DJI User466
There was nothing different than the last time hit return home no problem. No worming nothing and don’t know how to upload my flight
2018-5-21
Labroides
DJI User466 Posted at 2018-5-21 14:05
Go to the link in post #14
You will find instructions there
Follow them and come back with the link to the report it shows you.
2018-5-21
DJI Susan
I‘m so sorry to read the crash. Please kindly start a case and send the unit in for diagnosis: https://www.dji.com/support
Data analysis will be arranged if the drone is still under warranty period, and we'll offer you the corresponding solutions according to the analysis result.
2018-5-21
Jenee 2
Flight distance : 7852129 ft
Do you remember what message came up on the screen after you tapped RTH? It is possible that you may have tapped the arrow to land instead. The screen would have told you whether it was doing a RTH or landing. There should also have been a red cross that you could have tapped to stop the landing. Did you see this? Both RTH and landing can be cancelled.
2018-5-21
DJI User466
DJI Susan Posted at 2018-5-21 18:59
now that i looked at the log i see that the land botton was close to return home button on dji go app .and i'm sure i hit .land and i didnt know what to do and froze i'm sending it to you for repair .
2018-5-22
DJI Susan
DJI User466 Posted at 2018-5-22 06:25
All right. If you encounter any difficulties during the repair progress, feel free to contact us with your case number, we'll be here for help.
2018-5-25
zu_lu
Flight distance : 90459 ft
You are making it very difficult to be helped. You dont know how to upload your logs and then you state you have viewed them yourself? And then go on to admit you pressed the wrong button... This thread is a winner.
2018-5-25
Eric13
zu_lu Posted at 2018-5-25 11:34
That's a common scenario here:
People f*ck up and start a thread yelling at DJI and everyone.
Once they noticed their own fail you never here from them again.
2018-5-25
DJI User466
Eric why are you so upsesed with with Me. Nobody asked you
2018-5-25
Labroides
He asked in other places too and got his answer there.
2018-5-25
RedHotPoker
Multiple threads, on the same scenario.
RedHotPoker
2018-5-25
