On iphone SE you have 2 types of slow motion. First - 1080p in 120 fps and secont - 720p in 240 fps. When I use osmo mobile 2 with iphone SE in app dji go I choose slow motion mode and it is automaticaly shoot in 720p in 240 fps but I want to shoot 1080p in 120 fps. How can I change from 720p 240 fps to 1080p 120 fps in dji go?
The DJI GO App will only let you select the resolutions that it supports. If you see the option I don't think you can select it. There is a 3rd part app called Filmic Pro that does offer more resolution selections but you may want to email them first and ask what is supported for your device.
Kindly launch the DJI GO App then on the live feed page there will be a gear icon on the lower right side of your screen after that look for camera and you will have an option for you to check the available video resolutions under DJI GO App however before anything else make sure that the DJI GO App is on video recording mode.
DJI Tony Posted at 2018-5-21 13:29
The resolution of Slow Motion in DJI Go APP with Osmo Mobile 2 is 720P by default, if you would like higher resolution, please use the stock Camera, sorry for the inconvenience.
