just spent the past few days shooting filling up sd and internal storage ,i get home and the bloody thing wont connect to my pc , using latest assistant , tried all the usb ports, uninstalled usb drivers , uninstalled asistant still nothing
i managed to move the sd card to another device to transfer some photos but all my 4k footage is trapped on the internal storage , and not allowed to transfer 4k footage via wifi
Good day. I am sorry that you are having problems in connecting your Mavic Air to your PC. Let us try to do some minor TS steps. Let us try to restart your PC and try to connect the drone once again. When connecting the drone to the PC please use the USB cable that is provided by DJI. Thank you.
DJI Stephen Posted at 2018-5-23 09:44
hi stephen
i have restarted many times
using the supplied usb
reinstalled assistant
reinstalled usb drivers
tred multiple computers
its worked before with no problems but after a weekend away its stopped
DJI Stephen Posted at 2018-5-24 07:09
Good day, HANKthebastrd. Thank you for the reply. May I know the version of the DJI Assistant 2 that you have as of this moment. Thank you.
i figured out the problem , the supplied usb cable is broken , i purchased a new one and everything is working as it should , please advise everyone else that the supplied cable is substandard should be replaced. ribbon styled cables are fragile and tend to fray when bent laterally
I purchased a new cable from a local shop for $8 and it all works again as it should ! anyone having similar problems should give it a go! i think the ribbon styled cables can be broken when bent in the wrong direction , it looks fine from the outside but im guessing the copper has broken in the core , i figured it out when i plugged my smartphone into my pc with the dji cable and it gave the same error message , PROBLEM SOLVED!!! DJI UPGRADE YOUR CABLES!!!
It's not the cable for me! Guys try flipping the connector that goes to the drone upside down. Just twist and reinsert it. Boom problem solved! I did not need to buy a new cable.
