JBSonic
Flight distance : 586089 ft
I have had the Mavic Pro now for over a year and have flown it literally over 1000 times.
Since the last few weeks it has extreme interference, poor signal and poor controllability (lag).
Environment is not the issue, today I flew it in the same spot I have flown it hundreds of times and the signal was extremely bad, no matter the range. In fact it had a better signal being further away.
I use the DJI Crystal Sky monitor to make sure it is not the mobile device. You would think it would work well with Only DJI products...
Any idea about this? The image breaks up, drone responds slowly. It seem sporadic, regardless of location.
I have tried all the different transmission settings, 10mhz, 20mhz, Auto channel etc, no luck.
This was NEVER a problem in the past, I have flown this drone all over the world, often miles away without a hitch, now it is virtually unflyable.
Is this a broken firmware again or what is the issue ?
Anyone else have the same problems?
