Firmware updates. Mavic Pro
1093 8 2018-5-22
Goldchucker
Flight distance : 509 ft
With the new AC firmware updates, for the Mavic Pro, is it necessary to run a firmware update with each battery?  I wasn't sure if anything has changed in that regard.  I was never sure if the firmware was stored in the batteries or the AC itself.
Thank you,
Chuck
2018-5-22
StanfordWebbie
Flight distance : 178018 ft
Are you talking about a firmware update to the Mavic Pro, or an app update to DJI Go 4?
2018-5-22
Goldchucker
Hi StanfordWebbieerted
Good question.  I inserted the wrong nomenclature.  I meant the AC firmware not the DJI go 4 program.  Thank you for catching that.  I edited my origional post.
2018-5-22
Flybee
Flight distance : 2096562 ft
Sweden
it depends from which version you are going from and going to. If it's needed then the DJI GO app will tell you. Do it at home before next flight so you don't have to do it in the field.
The batteries have some kind of intelligence so that's why.
Good luck and happy flying
2018-5-22
Goldchucker
Hi Flybee.
Thank you for your input.    Appreciated.  I always upgrade at home.  I upgraded to the most recent AC firmware.  I repeated the process for all 4 of my batteries to be sure.  I wasn't sure if this procedure was necessary.
2018-5-22
DJI Diana
Flight distance : 2408 ft
Goldchucker Posted at 2018-5-22 22:10
Hi Flybee.
Hi Chuck, the firmware of the batteries should be consistent with the aircraft. You can update the firmware for the aircraft first, then connect the DJI GO4 app, if the battery also needs an update, there will be a notification "Firmware consistency refresh" in the DJI GO4 app, you can follow the notification to refresh the firmware for the battery. Any further doubts, please feel free to let us know.
2018-5-22
Goldchucker
Hi DJI Diana.
Thank you for confirming what I had suspected.  As I did update the batteries as well I feel more confident that I made the right move.
Thank you.
Chuck
2018-5-22
Goldchucker
Goldchucker Posted at 2018-5-22 23:23
Hi DJI Diana.
Hi DJI Diana;
Here are the 2 screen shots I get using a very new Dell computer running DJI Assistant 2 V 1.2.4
The first screen shot has a forign program appear in the upper left corner.  When I delete it, Screen shot 2 appears telling me to "Please reboot the Aircraft.  I'm running the latest firmware on my aircraft.
2018-5-28
Goldchucker
Goldchucker Posted at 2018-5-28 12:21
Hi DJI Diana;
Hi Diana
Please disregard this post.  It is in the wrong place.
Chuck
2018-5-28
