rent
Flight distance : 1773458 ft
Russia
For still images (photos), you actually want as fast a shutter speed as possible, so as to reduce / prevent any motion blur due to drone movement or movement of the objects you are photographing.
The images you posted -- are they off your DJI Go app? They are only 960 x 544 thumbnails, not the original full size images which should be 4056 x 3040. For best quality and editing, shoot DNG (raw). See if you can grab the original files from the SD card.
The exposure of your first image looks pretty good. I bet the full size image on your SD card would look good. The second one is perhaps slightly under exposed. Again, I think you will have a good file to edit with if you pull the file off the SD card. |
