Videos Not Showing in DJI Go 4.2.16
1770 5 2018-5-23
El Kab0ng
Flight distance : 156499 ft
After my last few flights I noticed that the DJI Go app that I used during the flight did not record the videos of the flights.  The videos were recorded using the onboard SD, but the videos didn't transfer, only the stills.  Has anyone else had this happen?  Does this have anything to do with my local cache being full?
Thanks.
~Carlos
2018-5-23
rent
Flight distance : 1773458 ft
Russia
Yes very likely due to cache being full.
2018-5-23
El Kab0ng
rent Posted at 2018-5-23 12:29
Right on.  I'll clear it and give it a shot.
2018-5-23
DJI Thor
Flight distance : 13602 ft
You can also check the Maximum Video Cache Capacity on the General settings, if you have enough space on your mobile device, you can enable a larger capacity. Besides, please check if the option "cache during video recording" is enabled. Hope it works for you.
2018-5-23
El Kab0ng
DJI Thor Posted at 2018-5-23 19:57
Looks like that did the trick.  I went into the settings and it was set to 2GB.  I upped it to Auto since I have more than 100GB free on my device.
Thanks for the help!
2018-5-24
DJI Thor
El Kab0ng Posted at 2018-5-24 07:32
Good to know that. Any further help needed, please don't hesitate to ask.
2018-5-24
