Fake battery as battery contacts cover
639 10 2018-5-24
Cirius
Flight distance : 277621 ft
Hello to all!  A little tip for you!  If you have an unused battery (not working anymore) you can dismantle the battery casing and remove the electronic parts inside then reinstalled the casing and your done, you have a fake battery acting as a cover for the connector and by the same time, keep the battery compartment away from dirt and dust!
Hope that help!
Cheers
2018-5-24
DJI Stephen
Good day. Thank you for the information.
2018-5-24
Wachtberger
Flight distance : 261509 ft
Sorry to say, but to me this looks like a solution to a non-existing problem...
2018-5-24
3-D
Flight distance : 635764 ft
how does this really help?  is your drone getting dusty  in it's case?
2018-5-24
HereForTheBeer
Flight distance : 5381368 ft
It helps keep the contacts clean of debris.  Anyone that travels a lot knows first hand that sometimes debris and dirty can get into places that makes no sense at all.  I actually had to clean debris out of the battery area of my Mavic Pro a few times when traveling. Either sand or crap found its way in while swapping batteries or while traveling.  Now I just keep a battery installed and it keeps crud out
2018-5-24
HedgeTrimmer
Intersting tip if you leave drone out for display.
2018-5-24
Cirius
For those who likes thanks!  For the others, thanks also for your feedback!!  I have to say that sometimes solutions are not for none existing problems and then, I call that "Prevention" !
Cheers!
2018-5-24
sky6105
Flight distance : 345653 ft
Cirius Posted at 2018-5-24 17:36
Cheers!
Good idea I know the little rubber caps they make do not stay on.
I just leave a battery in it for now.
2018-5-25
QuadKid
Flight distance : 482349 ft
I just cover the connector with a small piece of blue painters tape, easy on easy off.
2018-5-25
3-D
HereForTheBeer Posted at 2018-5-24 16:46
oh.  cool  i haven't had mine long enough to run into that kind of problem.
thanks.
2018-5-25
HereForTheBeer
3-D Posted at 2018-5-25 01:56
thanks.
Ya no problem.  Always good to prevent a problem especially traveling.
Personally I just keep a freshly charged battery installed so even less time wasted getting it up in the air + doesn’t let crud work it’s ways into area is shouldn’t be.
2018-5-25
