chrome88
Flight distance : 75945 ft
here's a cleaner repost. dji forums only give you 2 minutes to edit.
Osmo Mobile 1 Firmware v1.6.0.80
iphone X v11.3.1
Issue: When doing a motion timelapse, the Osmo at random times will reset to the centered position and then will continue recording while bouncing up and down
Weather was foggy, but NOT windy. Setup was on a tripod on a solid balcony. No shaking of the tripod or balcony detected during the timelapse.
Example 1 (10 secs, almost made it all the way through, but at the last frame, goes to center position)
Example 2 (16 secs, went to the neutral position almost right away, then started shaking)
Example 3 (20 secs, almost made it to the end. Went to center at the very end, then shakes)
