New CrystalSky Firmware Released
123Next >
14957 114 2018-5-25
DJI Support
Flight distance : 2408 ft
Overview
  • Date: 2018.05.25
  • CrystalSky Firmware: V02.06.06.00
  • DJI GO 3 App: V3.1.38
  • DJI GO 4 App: V4.2.16
  • DJI Pilot Beta: V0.5.1
What's New?
1. Updated DJI GO 4 app to version 4.2.16.
2. Updated DJI GO 3 app to version 3.1.38.
3. Optimized temperature control logic to improve the CrystalSky's performance in high-temperature environments.
4. Added support to Phantom 4 Pro V2.0.
5. Updated in DJI GO 4 app:
  [Inspire 2]
  • Added Point of Interest (POI) functions within intelligent flight modes. Set a POI on the map as the point of interest function sub pattern.
  • Fixed a bug where the DJI GO 4 app will reset the camera frame rate and resolution when connecting a device.
  [Mavic Air]
  • Optimized APAS interactive experience.
  • Added additional warning messages when propeller blades are getting iced up in low-temperature environments.
  • Added max flight speed control in ActiveTrack. Users can now switch between Velocity Priority and Obstacle Avoidance Priority modes.
  [General]
  • Simplified and reduced pop-up messages.
  • Optimized offline map performance.
  • Supported media sharing in Playback.
  • Updated the FPV map. Users can now check GEO Zone within 50 km.
  • Updated DJI Products Terms of Use and DJI.
6. Privacy Policy
  • Improved the GEO Zone database upgrade process.
  • Optimized low power take-off prompt in sub-zero temperatures.
2018-5-25
Rob W
Flight distance : 75413 ft
Sweden
Great, finally! Thank's!
2018-5-25
Wachtberger
Flight distance : 261509 ft
This is fantastic news, thank you very much DJI!
2018-5-25
SubUser
Flight distance : 74140 ft
I updated CS5.5, so far I can see everything is working OK.
I took it out for a small test-flight.
It looks like the Ipad mini 4 with the v4.2.16.
The offline maps are back.
Even the OTG cable is working with the Spark.
The compass of the CS5.5 is still a bit jumpy, but I did not calibrated the compass again on the CS.
Thanks, good job !
2018-5-25
nixuspix
Flight distance : 2771453 ft
Latvia
Unbelievable DJI! Thank You so much.
2018-5-25
Montfrooij
Flight distance : 1809849 ft
Nice to hear.
Now just start saving for one
2018-5-25
nixuspix
Latvia
Can You please update download links?
2018-5-25
SubUser
nixuspix Posted at 2018-5-25 06:21
I did an update by the CS on WiFi.
It does not work for you ?
I did some more flying - 4 batteries - quick shots - active track - sport mode.
No loss of connection - all OK.
A very hot day over here - in the sun - no overheating.
2018-5-25
nixuspix
Latvia
SubUser Posted at 2018-5-25 06:56
Yep, the update has reached my CS as well. Will test tomorrow. But thank you for your testing - looks very promising.
One small bug discovered - when i try to rename the downloaded map Region 1 for anything else, then it comes to mistyping....
2018-5-25
Matioupi
Flight distance : 922569 ft
is there a firmware download link to go the SD card way rather than OTA (both for 5.5 and 7.85) ?
2018-5-25
Paco572
thank you.
2018-5-25
Wachtberger
Matioupi Posted at 2018-5-25 08:48
Hi dear friend, no download link. You can only update online.
2018-5-25
BCD Video
Flight distance : 672103 ft
Thank you, thank you, thank you!!!!
2018-5-25
Anthony566
Flight distance : 2488944 ft
What about offline maps ?? Is this still broken ?
2018-5-25
SubUser
Anthony566 Posted at 2018-5-25 16:20
Offline maps are back again.
Replay flight recording is working.
The on-screen keyboard has a small bug.
You have a big USB-port on the CS, this is a normal host port for mouse/keyboard.
Put a small/simple USB keyboard on this port, this will work for naming and renaming.
A big gamer-keyboard will maybe draw to must current or need a special driver.
If you want to change a existing file, click on the map-icon upper-right.
If you keep your finger on the file-bar, it will show: delete/rename.
If you click on the ">" you will see the map.
2018-5-25
Matioupi
Wachtberger Posted at 2018-5-25 12:45
Packages are actually there : and the SD method of course do work...
http://mydjiflight.dji.com/file/links/ZSA_pack_2660_20180525
http://mydjiflight.dji.com/file/links/ZSB_pack_2660_20180525
2018-5-25
ToscanaDrone
Flight distance : 7567142 ft
Updated but always this problem!
2018-5-25
SubUser
ToscanaDrone Posted at 2018-5-25 23:23
[view_image]
You refer to the "Map Loading" ??
2018-5-25
Forestjim
Flight distance : 4545135 ft
Wow.. updated both CS’s 5.5 & Ultra
Quick fly with both.
All good
Offline Maps.. I can’t work out what region to download for Australia
I’ve downloaded 1-9 so far
2018-5-25
Wachtberger
Matioupi Posted at 2018-5-25 20:39
Wow, I didn't know about this. Sorry that I gave you the wrong answer then.
2018-5-26
JohnCom
Flight distance : 292526 ft
Yes thank you dji for your fast fix on the CS.
But please next time check everything out before you post us to download some thing that don't work with everything.This will save a lot of mix up's.
2018-5-26
nixuspix
Latvia
Have flied 3 batteries with updated 5.5" CS and Spark. OTG is working good, flight record is working good, offline maps working good, but only can't rename default Region1..... before and after saving.
So thank You DJI and please try not to spoil all good we have now during prepare of the next update
2018-5-26
Elektrica Atellani
Flight distance : 8397772 ft
Awesome update
2018-5-26
QuadKid
Flight distance : 482349 ft
Yup, just flew 3 packs with the MA and 3 Packs with the P4P, everything worked well, had one App crash with the MA at about 300 meters out, just restarted and all was fine the rest of the day.
2018-5-26
shamelin
Flight distance : 8058 ft
I get an error 800 failed issue.  I have the 5.5 what download above is what I need?
2018-5-26
QuadKid
shamelin Posted at 2018-5-26 12:59
Go to your settings in the CS, scroll down, look for updates, tap check for updates it should tell you updates are available, the newest update is 02.06.06.00. Make sure you have a good Wifi connection.
2018-5-26
shamelin
QuadKid Posted at 2018-5-26 13:10
I am letting it download the update but keep getting error 500 after it reboots to do the update.  There are 2 download links above but they are labeled differently.  Which one is for the 5.5 screen?
2018-5-26
shamelin
which one of these are for the 5.5 screen?
2018-5-26
BCD Video
Just flew 3 batteries on a standard P4 with all current updates and here are the bugs I encountered.
1) Go4 app crashed 2 times
2) when starting Go4 app I got the msg “DJI GO 4 isn’t responding” at two different times
3) can’t name or rename offline maps
4) encounterd video lag a couple of times
2018-5-26
shamelin
well this is great I tried the download again now all I get is the DJI screen and just received this and got account set up.  I have not even had any flight time with this screen
is there any recovery mode for this?
2018-5-26
Mike-the-cat
Flight distance : 14411854 ft
Singapore
SubUser Posted at 2018-5-25 16:33
Yes, these features are back working. Glad DJI fixed this.
2018-5-27
fans802e59b3
Flight distance : 327352 ft
This is a good vid to watch on off line maps now the update has happened..
2018-5-27
Matioupi
shamelin Posted at 2018-5-26 13:14
A = 5.5 B = 7.85
2018-5-27
Wachtberger
How did you find these links and to which website do they belong? When I only type in the domain, nothing shows up.
2018-5-27
step3fans
Flight distance : 224177 ft
BCD Video Posted at 2018-5-26 13:16
how to rename offline maps.  after every letter or number press the backspace key it worked for me
2018-5-27
JMR58
Flight distance : 591837 ft
step3fans Posted at 2018-5-27 10:06
Thanks for the Tip, works for me also!
2018-5-27
TheMann58
Flight distance : 14554101 ft
I downloaded the update for my Crystalsky UB today directly from my Crystalsky main screen via WiFi and it then updated with no problems.  I flew two full batteries this afternoon - one after the other - in sunny 95 degree F Houston, TX weather with no problems. For the other lucky folks like me that were not experiencing overheating of their Crystalsky UB BEFORE the latest update, my experience today indicates that the latest firmware update doesn't screw anything up for us. I was flying today with my new DJI Crystalsky Monitor Hood installed, which helps keep direct sun off the screen. I don't need the hood to see the screen, but I thought it would help keep the screen cooler in direct sun as summer heat ramps up in the Gulf Coast of the U.S.
FYI - Last week (before updating the Crystalsky firmware) I was in Phoenix, AZ with my Crystalsky UB outside in the blazing dessert sun (95F-100F) for 3 hours with no sun hood of any kind and never received a single overheat warning. I flew a total of four batteries over three hours. Shortly after taking off on the 4th flight in Phoenix, the DJI GO 4 app did freeze up, but after restarting the Crystalsky, the DJI GO 4 app worked just fine with no further issues.
2018-5-27
Matioupi
Wachtberger Posted at 2018-5-27 06:44
I just looked how the links are crafted on the DJI official crystal sky page :
https://www.dji.com/fr/crystalsky/info#downloads
(hovering the mouse over the links in the firmware sections shows the full url address)
and then I "guessed" what the new fiel name should be... They just forgot to update the page yet, still referencing the old firmware version... which should be archived by the way in case for some reason need to go back one version...
2018-5-27
fansd15ad1b8
Flight distance : 671995 ft
I have already downloaded the latest software but the Crystalsky got hot in the process and stopped, I later resumed the download when it cooled down, my question is, can I re-download in an attempt to
2018-5-28
fansd15ad1b8
I downloaded the latest software, it took two attempts because as I was downloading the Crystalsky got hot and shut down. When it had cooled I resumed and eventually succeeded. My question is can I re-download the software again in the hope I can do it in one go?
2018-5-28
123Next >
