DJI Natalia
Thank you for raising this concern. As of the moment Phantom 4 Pro Obsidian is not available on our DJI Store website. We do not know yet as to when it will be available. No worry, I am going to communicate as well to the relevant department for us to check for the availability of this unit. You may also check with the nearest store or dealer where you located. For the meantime, we do have our new release Phantom 4 Pro V2.0. The difference between the Obsidian and V2.0, the Phantom 4 Pro Obsidian comes in a matte black casing. Functionally wise, the Phantom 4 Pro Obsidian is the same as the Phantom 4 Pro. The Phantom 4 Pro V2.0 is equipped with an OcuSync transmission system, which allows the drone to connect to DJI Goggles wirelessly. The Phantom 4 Pro V2.0 also features an upgraded propulsion system with FOC sinusoidal driver ESCs and 9455S quick-release propellers that reduce noise and make the drone more aerodynamic. For more details you may click on the following links:
https://store.dji.com/product/ph ... ducts&vid=43151
https://www.dji.com/phantom-4-pro-v2/info#specs |
