How does DLOG work with X5S H264 ?
1770 9 2018-5-25
YOYOMAN
Flight distance : 676260 ft
Réunion
Hi,
I plan to buy an I2 & X5S (without licences...) and I would like to know how the DLOG profil works with X5S and H264 codec?
I've seen it was iso blocked at 500 (as it is with P4P) but it seems to be unlocked now?
I've also read earlier in 2018, a firwmare upgrade made the DLOG with I2 h264 working worse than Mavic DLOG :https://forum.dji.com/thread-128199-1-1.html
So,  could you give me more information about the current quality of DLOG & h264 I2 X5S please?
thanks !
2018-5-25
iSkyUnmannedSystems
Flight distance : 7152087 ft
Currently dlog on the h264/5 files is been turned off on the I2. You only have cinelike and normal colour spaces. What most people have been doing since the X5 days is to set the colour space to normal and then set colour, contrast and sharpening to -3. It’s flattens the grade and works quite nicely for a bit of colour correction and grading in post, don’t forget to add a little bit of sharpening back too.
2018-5-25
YOYOMAN
Réunion
iSkyUnmannedSystems Posted at 2018-5-25 21:26
thanks for your advices, it will help a lot!
When you said DLOG is tuned off, do you mean DJI disable DLOG profil at the moment?
thankss =) =)
2018-5-26
allanart
Flight distance : 1050577 ft
The latest firmware (V01.02.0100) supports D-LOG in H254/5 and works fine.
See my short comparison video at
Kind regards
Allan
2018-5-26
YOYOMAN
Réunion
allanart Posted at 2018-5-26 03:29
Kind regards
thanks you so much !
Can you confirm that the ISO is not blocked at 500 anymore when using DLOG?
2018-5-26
allanart
No ISO can be set as normal.
Regards
Allan
2018-5-26
YOYOMAN
Réunion
allanart Posted at 2018-5-26 10:42
Regards
Allan
can't wait to get my new I2
2018-5-26
fansdb6ff1f7
Flight distance : 1998786 ft
I have DLog working on my I2. It was terrible before the latest FW upgrade but now looks good. ISO is Not fixed at 500 on the I2 anymore .. though strangely it is on the P4P. My go to  I2 setup is  ipadmini4/MicroSD/X5s/h264/Dlog/minus 1 contrast & Saturation. minus 3 sharpness.
2018-5-26
iSkyUnmannedSystems
See my short comparison video at  https://vimeo.com/266851665
Kind regards
Mmm not showing here, what version of the app are you using as I’m on the same firmware with the I2.
2018-5-27
jdmagoo
Flight distance : 1478842 ft
I have it on the latest version of the iOS app
2018-5-27
