Regijean
Ok. The GPS is aft 20 mm and 200 mm above the CG. It's difficult to determine CG by photo, but that would put your vertical CG underneath the bottom plate (because your N3 is 20mm above vertical CG).
This would mean that everything below the bottom plate equals the same weight of everything above your bottom plate; eg., the batteries, motors, propellers and electronics all equal the weight of camera and landing gear. Does the batteries, motors, propellers and electronics all equal the weight of camera and landing gear? If not, then your numbers are wrong.
Is there a point on the vertical axis (z) where everything above weighs the same as everything below? |
