paul2660
Flight distance : 10331 ft
You need to download Assistant 2 for Phantom. Older version of Assistant 2 will not work with P4 vr2
You can download the “assistant 2 for Phantom” on the main downloads page for the P4 Vr 2.0.
One note, the software will connect I.e. you can get to the screen where you see the USB plug move to the compputer, and then you will get nothing.
Program will not read firmware or flight logs from the drone. I have tried to use it on PC (win10) or Mac (high sierra).
Had a post on this forum about this problem and got a response that made no sense from DJI, something about the “program can read anything yet as there has not been an update to the base firmware”. OK, great, you still should be able to see the firmware. And BTW, the battery I had needed to be updated, which you can normally do from the Assistant software NOT possible. Had to go the djigo4 app for that.
NET, you can’t get to the flight logs, thus you can get important info from the drone. This issue needs to be fixed IMO.
Not sure if you can pull the .DAT from the drone without assistant software.
Paul Caldwell
