DJI Thor
Flight distance : 13602 ft
Salmonslayer Posted at 2018-5-27 08:39
Thanks msinger, I have very little open area where I live to test it on one side the water and the other mountains, all flat area if you can find it is NFZ , so I have to basically find it over water.
So if I understand it correctly msinger, if I fly 20ft away from the boat only 15 feet in the air if for any reason I loose controller contact (and its set to hover) then it will continue to hover 15ft above me.
Thanks
This is correct. But please also note smart RTH might still be enabled if the current battery level reaches the Smart RTH point.
Like Jenee 2 mentioned above, you can refer to the manual.
Besides, flying in a boat especially a moving boat can be dangerous, please be cautious.
