DJI Thor
Flight distance : 13602 ft
ShadyDealer Posted at 2018-5-27 15:31
The controller is still able to control the Mavic so I guessnitsnth phone that’s disconnecting from the Mavic. Still, it doesn’t give me confidence flying it especially in a foreign country and over the open space over the sea.
If the drone is controllable, you can try Capt of Enterprise on 5#, check if it is the cable that connects the RC and mobile device doesn't fit tightly. You can also check if the micro USB port is damaged, try to use the bottom USB port. Besides, may I know which iOS are you using? You can try to reinstall the latest DJI GO 4 app, remember to do a backup like syncing the flight record and saving the pics and videos before your reinstallation. See if it helps.
