Need help with abnormal fligth
884 14 2018-5-27
1b2o3b4s5t6a7p8
Hi, took my phantom 3 out of the box after 6 months (winter) charged everything up, reloaded the go app and lichiw app.  Everything looked fine until I tries to start the motors manually, nothing, tried auto start, and it flew irractically.
Stick on mode 2
both calibrations were completed
not sure what to do. App said no update.
Before I send it out to where ever, wanted some quick step by step help from the experts, that is, not me.
Mr. Bob
2018-5-27
Peterx
Flight distance : 1499708 ft
Did you look into the app what version of Go App and Firm ware it has?
Can you fire up the motors and fly?
2018-5-27
Droner500
I have heard before that the lichi app sometimes causes weird problems like that. Also, did you have the DJI go app and lichi running on your device at the same time? I think that might have caused problems with the drone or it might have confused it because one app was telling it to start flying and the other wasn't.
2018-5-27
Labroides
Flight distance : 9991457 ft
Updates/not updating or Litchi vs Go does not cause anything like what you describe.
What you should do is look at the recorded flight data to see if that has clues to the real cause.
Go to http://www.phantomhelp.com/LogViewer/Upload/
Follow the instructions there to upload your flight record from your phone or tablet.
Come back and post a link to the report it gives you.
2018-5-27
DJI Susan
Hello Bob, just to verify, are you trying to start the motors by CSC(push both sticks to the bottom inner or outer to start the motors), right? If yes, have you tried to calibrate the RC? I'd advise testing this feature in the outdoor with good GPS signal to see if the issue appears frequently.
2018-5-28
1b2o3b4s5t6a7p8
Thank you so much for helping me everyone looks like I have 3.1 .38 Go app only had one application running I uninstalled the litchi just to make sure. I like to take a video of it so you guys can see up as hard as I'll follow your instruction and test it today again before I can't figure it out or should I send it to get repaired someone I can trust and won't charge me too much.ps how do I respond to each of you individually or do I just make a general responce
2018-5-28
Labroides
1b2o3b4s5t6a7p8 Posted at 2018-5-28 04:44
It would make sense to attempt to find out if there was a problem and what that might be before thinking about sending it to get fixed.
See post #4
2018-5-28
1b2o3b4s5t6a7p8
Droner500 Posted at 2018-5-27 12:03
Hi, Just figured out how to reply individaully.
3.1.38 go app
2018-5-28
1b2o3b4s5t6a7p8
Hi,
I uninstalled the litchi app before the test.  I was thinking the same thing.  Bob
2018-5-28
1b2o3b4s5t6a7p8
Labroides Posted at 2018-5-27 14:54
Thank you, I will try today.  I do prefer to use litchi for FPV flying. Bob
2018-5-28
1b2o3b4s5t6a7p8
DJI Susan Posted at 2018-5-28 01:04
Hi Susan,
yes, both sticks together in or out nothing. but i didn't try to calibrate the drone unless calibrating the IMU and compass does that, otherwise not sure how to do that.  I do see a small port on the drone. Do I need to go to dji to do that?
2018-5-28
1b2o3b4s5t6a7p8
Labroides Posted at 2018-5-28 05:07
See post #4
Yes, I agree.
Bob
2018-5-28
Eric13
Flight distance : 13982031 ft
1b2o3b4s5t6a7p8 Posted at 2018-5-28 06:35
Hi Susan,
Susan means calibrating RC=Remote Control. The drone is often referred to as AC=Aircraft.
See here a tutorial:
2018-5-28
DJI Susan
Hi Susan,
Sorry for the confusion. Please refer the tutorial video in 13# and try to calibrate the remote controller to see whether it helps. If still not, I'm afraid that you have to send the unit in for diagnosis. You can start a case from here: https://www.dji.com/support
2018-5-31
stuka75
Flight distance : 85682 ft
IF you uninstalled the apps over the winter, and then reinstalled, you may have to log into DJI again. FWIW.
2018-6-2
