KedDK
Flight distance : 1133038 ft
Denmark
SafetyGuy71 Posted at 2018-6-19 15:33
Yes, sir. I log in easy enough, check the switch settings (5 of them). Still, in the center of the screen is the illustration of plugging into USB, but with a question below saying "Learn How to install into Inspire 2?
Well not good to hear, Aardvark has a point about the driver installation but i think that part only is a problem when attempting to calibrate the VPS sensors, however you might need to install Assistant2 with the driver signing check disabled (windows).
Last suggestion beside a cable defect would be to try a previous version of Assistan2, Mike Singer has been so kind to collect an archive that can be found at phantomhelp.com. |
